  3. Strange Dot on final Footprint ?
  • Replies 9
  • Subscribers 166
  • Views 20210
Cailloux
Cailloux over 6 years ago
Picture 1 show a Shape created in Allegro PCB Editor 16.6, file LTshape.ssm      The Shape Origin is dead center of the outline 565X400 mils.    This Shape is utilized in the PadStack Editor to create a special Pin for a custom Footprint.
Picture 2 show the PadStack Editor first page with drill size and offset. File  LTshape16.pad         Picture 3 show the PadStack Editor page 2 with that LTshape utilized as the BEGIN LAYER for copper area. Picture 4 show the actual Package (footprint) finished with Outline, padstacks for pin 1,2,4,5 and that special Pin 3 LTshape. Its origin is also dead center, same as LTshape.ssm
Notice the round dot at the bottom of Pin 3. It only appear in the Package drawing, not in the original Picture 1, the actual LTshape.ssm or LTshape.dra
Picture 5 shows that same Footprint in the final board in PCB Editor. That same dot, now pink, is still there and cannot be selected separately. When using the Find Option and selecting each object separately, the only way to select Pin 3 is when Option > Pin is selected. Then I can hover on the dot near Pin 3 and the whole LTshape lights up as pin 3, but not the pink dot. There is absolutely no way I can select that dot as an object. There is no way to know the existence of that dot except by looking at it. Cannot be deleted, cannot be selected, can only be invisible if I use the Color Visibility manager and disable all 4 layers, TOP GND VCC BOTTOM. If I turn On TOP then the dot becomes pink. With GND On the dot is green, VCC On will get a Red dot, BOTTOM On will not show the dot but Pin 3 turn On since LTshape is the actual Net connected. This Net is not GND nor VCC, it is N357726.
Where is this dot coming from and why is it not a selectable object ? Why can I not delete it ?
  • excellon1
    excellon1 over 6 years ago +1
    It could be a cline or cline segment on the top layer of the board (Assuming top layer is pink) The colour should give you an indication of what layer it is on. Try turning layers off to see. If you…
  • RandyR
    RandyR over 6 years ago in reply to Cailloux +1
    Yes, you can add vias to *.dra files. Try Layout->Connection then click once on the location you want the via to start routing (your default via should now show in your option tab), then right-click "Add…
  • steve
    steve over 6 years ago in reply to Cailloux +1
    The Options pane won't show the VIA until you left click to start the Connection. By default it uses the one at the top of the vialist but you can select others if you have more than one in the vialist…
  • Cailloux
    Cailloux over 6 years ago in reply to steve
    Great ! Thats what I thought. But now I am in PCB Editor trying to build a brand new Package. First thing I did was to put my special Pad LTshape as a SM pad. Now that my LTshape SM pad is placed on my Design window I am trying to Layout > Connection and I can see in the Option window that no Via is defined by default. If I want to chosse one, nothing is available. If I go the Constraint Manager and try to edit the default VIA there is one and I can even change it for another VIA. Still the Option window will not let me choose what Via to use. So the question now is: How do I define a default Via that I can use when in PCB Editor Package mode?  I kind of lokked pretty much anywhere I can think but that seems like a dead end. Any suggestions ? Can we actually put Vias when in Package mode?
  • RandyR
    Yes, you can add vias to *.dra files.  Try Layout->Connection then click once on the location you want the via to start routing (your default via should now show in your option tab), then right-click "Add Via".
  • steve
    The Options pane won't show the VIA until you left click to start the Connection. By default it uses the one at the top of the vialist but you can select others if you have more than one in the vialist.
  • Cailloux
    Yes it works !  Far from being an intuitive UI but alas I got it. Thanks guys, much appreciation.
