  3. What are these errors after using automatic routing?
  • Views 15834
davismeissner
davismeissner over 6 years ago
  I also have some with K C and some with P P and P S. I can not find a library of where to look up what these are?
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    Look for 'DRC Error Marker Code Definitions' in the on-line help...
  • davismeissner
    davismeissner over 6 years ago in reply to DavidJHutchins
    Ahhh.. Thank you! I could not for the life of me figure out what they were called.
  • RFinley
    RFinley over 6 years ago
    Also, if your find/select filter has DRC errors enabled, you can select these flags and RMB- "Show Element".  More useful information including the objects causing the conflict.
