  3. Negative Tolerance in Relative Propagation Delay
  • Views 15308
saicharan
saicharan over 6 years ago
In Electrical constraints when we want nets in a group to be +-20mil w.r.t to a manually selected target 0:20 tolerance works fine, but before we could reach this conclusion, the tool also accepts -20:20 mil as tolerance value  and the results generated are difficult to understand, what actually does it mean to have tolerance set to -20:20 mil?
  • steve
    steve over 6 years ago +1
    This cell is made up of Delta:Tolerance so you are setting a Delta value with +/-20 tolerance. Take a look at www.parallel-systems.co.uk/.../Match_groups.pdf for more detail
  • steve
  • saicharan
    saicharan over 6 years ago in reply to steve
    thank you , helped a lot
