  3. How to get the visibility of COLOR - CLASS/SUBCLASS?
  • Subscribers 159
  • Views 2168
VytasR
VytasR over 5 years ago
I want to know if the layer is visible or not after I use:
color -toggle "PACKAGE KEEPOUT/TOP"
How can I get it?
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    try using
    skill axlIsVisibleLayer("PACKAGE KEEPOUT/TOP")
    if the return value is 't' then it is visible
    if the return value is 'nil' then it is not
  • mcatramb91
    mcatramb91 over 5 years ago
    If you are looking to just turn the layer on without checking you could use the -vis option instead of -toggle.
    color -vis "PACKAGE KEEPOUT/TOP"
  • VytasR
    VytasR over 5 years ago in reply to DavidJHutchins
    Thanks, that's exactly what I needed.
    Some offtopic:
    Why this works:
    color -toggle "PACKAGE KEEPOUT/TOP" ; skill axlIsVisibleLayer("PACKAGE KEEPOUT/TOP")
    And this gives always a "nil"
    color -toggle "PACKAGE KEEPOUT/TOP" ; skill println("toggle PACKAGE KEEPOUT/TOP (t- visible / nil - invisible):") ; skill axlIsVisibleLayer("PACKAGE KEEPOUT/TOP")
