  3. Checking Airgap between via and Shape Segment
  • Views 16511
vimaldevlpr
vimaldevlpr over 6 years ago
Hai,
I'll try to check the airgap between via and shape segment for cut out checking.
input value in run time. If the airgap value is lesser then input value means they shape segment has to be highlight.
I'll tried but it is not working properly can anyone please re correct my code.
axlCmdRegister("cutkar" 'cutkar ?cmdType "interactive")
procedure(cutkar()
axlClearSelSet()
axlSetFindFilter(?enabled `("NOALL" "VIAS") ?onButtons `("VIAS"))
vias = axlGetSelSet(axlSelect(?prompt "Select vias by pick or window."))
 if(vias then
  axlClearSelSet()
  axlSetFindFilter(?enabled `("NOALL" "SHAPESEGS") ?onButtons `("SHAPESEGS"))
  shpseg = axlGetSelSet(axlSelect(?prompt "Select shape seg by pick or window."))
   if(shpseg then
      foreach( shp shpseg
       _AirGap = axlAirGap(vias shp)
        val = atoi(axlUIPrompt("Enter the Site To Place components :"))
        if( val > _AirGap
        axlHighlightObject(shp)
        print("found")
  • luanvn81
    luanvn81 over 6 years ago +1
    Hi! 1/ axlGetSelSet return lo_dbid, so you should use foreach( ) for each dbia of via or use car() for using first via. 2/ I think you should define layer for axlAirGap() forexample shp->layer 3…
  • luanvn81
    Hi!
    3/  val = atoi(axlUIPrompt("Enter the Site To Place components :"))  should put in more  suitable location.
    4/  if( val > _AirGap   ==> missing then
    I have fixed your code.
    procedure(cutkar()
    axlClearSelSet()
    if(vias then
    axlClearSelSet()
    if(shpseg then
    foreach(via_db vias
    foreach(shp shpseg
    _AirGap = lastelem(axlAirGap(via_db shp shp->layer) )
    if(val > _AirGap then
    ;axlHighlightObject(shp)
    printf("found")
    Tks
    Luan.
  • vimaldevlpr
    vimaldevlpr over 6 years ago in reply to luanvn81
    Kindly Thank you luan..
