  3. Pad_Designer.exe in 17.4?
  • Views 16166
rbrodner
rbrodner over 6 years ago
I am currently using PCB Editor 17.4 and I am trying to download a design to import into my project and the script fails and says 'pad_designer' is not a recognized command.  I know I have done this in the past when I was using version 16.6 and didn't have any problems.  Did this executable command go away in 17.4?  Any ideas on how to fix or run these library download scripts in 17.4?
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    In 17.x pad_designer was replaced with padstack_editor
  • rbrodner
    rbrodner over 6 years ago in reply to DavidJHutchins
    So if I just edit the .bat file and replace pad_designer with padstack_editor, these design file scripts will run?
