  3. axlSaveDesign and axlRunBatchDBProgram
  • Views 16218
Ejlersen
Ejlersen over 6 years ago
Hi All
Since axlRunBatchDBProgram runs on a saved design then it can be necessary to save the board before running axlRunBatchDBProgram.
However, reading the documentation for axlSaveDesign it has the following clause "Use axlRunBatchDBProgram, if the intent is to save the design to run another program."
There are however no documentation on saving the design using axlRunBatchDBProgram
So what is the solution here?
Best regards
Ole
