  3. How to access a variable one level above prog() if not declared...
  • Views 14754
How to access a variable one level above prog() if not declared in current prog()
leto
leto over 6 years ago
Hello All,
To avoid using a long name (such as proABC.localVar1 ), how do I access the variable "localVar1" that is outside current prog()?
procedure(proABC()
   prog( (localVar1)
       localVar1 = 1
       if( (t)
            then
            prog( ()
               localVar1 = 3       ;; note I did not declare any variable named "localVar1" in this prog(). I would expect this to use the variable declared earlier
               printf( "localVar1 in IF statement = %d " localVar1)      ;; this prints 3
       printf( "localVar1 outside IF statement = %d " localVar1)      ;; this prints 1
Thanks All
