  3. Trim Silkscreen Outside Edge of Board
  • Views 16007
Maxxxx
Maxxxx over 6 years ago
Hello
Is there any way to trim the silkscreen outside the edge of the outline? I am using the SILKSCREEN_TOP subclass. Thank you.
  • CadAce2K
    CadAce2K over 6 years ago
    Delete/Cut (element: line)
  • Maxxxx
    Maxxxx over 6 years ago in reply to CadAce2K
    Look like it removes the entire symbol. Would that be possible to remove part of the silkscreen of a particular symbol?
  • CadAce2K
    CadAce2K over 6 years ago in reply to Maxxxx
    Element: Line (only!). You obviously have the 'symbol' selected in you Find Filter. Turn all off except Line or Line Segment and delete.
  • Maxxxx
    That works. Thank you so much!
