  3. What causes BoardOutline/Cutouts to not show in the 3D canvas...
  • Views 5203
What causes BoardOutline/Cutouts to not show in the 3D canvas?
RFinley
RFinley over 6 years ago
Not finding help on diagnosing this on CDNS website or just what it is expecting.  Just me?   B-)
17p4 sp6
  • CadAce2K
    CadAce2K over 6 years ago
    The 3D canvas needs a lot of work within Allegro, sorry. Just my opinion. I mess with it occasionally, but not often. There is a 'proper way' to do the cutouts, but haven't played with it enough to figure it out completely. The board outline should always come up though, unless maybe it's not contiguous (a complete outline, end to end). If you run into fixes let us all know. Thanks.
  • steve
    steve over 6 years ago
    Firstly - there is Hotfix S007 but are you using the correct subclasses? Sine 17.2 was introduced Outline is no longer the preferred subclass, you should use Design_Outline (which must be a closed shape) and Cutout for cutouts. Both are under Board_Geometry class.
  • RFinley
    RFinley over 6 years ago in reply to steve
    I misspoke.  Yep.  have an un-filled shape on design_outline and shapes on cutout that were copied from ncroute_path.  Wanted to make sure everyone understood the question.  B-)
    off to download sp7.   Thanks steve!   (wow, there's two parts this time..)
  • RFinley
    RFinley over 6 years ago in reply to RFinley
    SP7 fixes everything.  Thanks Steve!
