  3. Unused Via Suppression won't stay
  • Subscribers 166
  • Views 2507
Lock2002
Lock2002 over 6 years ago
I have a problem where "unused via suppression" occasionally gets selected in the cross-section editor. It's the same layers every time. I am using constraint manager in OrCAD, but I'm certain that I've imported the latest tech file from the board. Anyone see this before?
  • steve
    steve over 6 years ago
    Not seen this but you could have this information stored in the technology file (stackup can be part of that) so try importing the tech file into a new blank design and see if it gets set. If it does and you don't need it you'll have to re-create the tech file.
  • AvengerThanos
    AvengerThanos over 6 years ago
    It could be w.r.t to Tech file. Might the selections on tech file is enabled for "unused via suppression"
