  3. Cline to other Cline segment Airgap
  • Views 19543
vimaldevlpr
vimaldevlpr over 6 years ago
I need one help can any one please help me out from this.
The selected Cline alone has to check the air gap of every cline segment present in the board in that the input value will get by run time. if the airgap value is lesser than input value the cline segment want to be highlight. I'll tried but I shows error can anyone please re correct it.
E- *Error* greaterp: can't handle (4 > nil)
procedure(checkcseg()
axlClearSelSet()
axlSetFindFilter(?enabled `("NOALL" "CLINES") ?onButtons `("CLINES"))
clineschk = axlGetSelSet(axlSelect(?prompt "Select Clines by pick or window."))
if(clineschk then
axlClearSelSet()
axlSetFindFilter(?enabled `("NOALL" "CLINESEGS") ?onButtons `("CLINESEGS"))
clinesegchk = axlGetSelSet(axlAddSelectAll())
val = atoi(axlUIPrompt("Enter the Max Airgap value :"))
if(clinesegchk then
foreach(cln_db clineschk
foreach(csg clinesegchk
_AirGap = lastelem(axlAirGap(cln_db csg csg->layer) )
if(val > _AirGap  then
axlHighlightObject(csg)
print(csg ->xy)
printf("found")
  • Kirti Sikri
    Kirti Sikri over 6 years ago
    It is because the code doesn't handle _AirGap to be nil.
    Once you handle that before val > _AirGap error should go away.
    Kirti
  • vimaldevlpr
    vimaldevlpr over 6 years ago in reply to Kirti Sikri
    Hai Kirti,
    That's the thing I don't know how to handle it. can you please give me a solution for this.
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    replace the following:
    with:
    when(equal(cln_db->layer csg->layer)
    (data = (axlAirGap cln_db csg (csg->layer)))
    when(data
    (_AirGap = (lastelem data))
    then add
    at the end to close the 2 "when(" statements
  • vimaldevlpr
    vimaldevlpr over 6 years ago in reply to DavidJHutchins
    Hi David
    I'll updated by checking by name the NET is passing but Airgap value is not measuring could you please help me out.
    procedure(clineAirgap()
    in1 = infile("Netlist.lst")
    a = nil
      while(gets(cseg1 in1)
      cseg1 = car(parseString(cseg1 "\n"))
      when(cseg1 push(cseg1 a))
      close(in1)
          cseg2 = axlSelectByName("NET", a)
      if(cseg2 then
       axlClearSelSet()
       cseg3 = axlGetSelSet(axlAddSelectAll())
       val = atoi(axlUIPrompt("Enter the minimum airgap :"))
       if(cseg3 then
       foreach(chk1 cseg2
        foreach(cseg4 chk1 ->branches
         foreach(chk cseg4 ->children
         when(chk->objType == "path"
          foreach(cseg5 cseg3
           when(equal(chk->layer cseg5->layer)
            (data = (axlAirGap chk cseg5 (cseg5->layer)))
             when(data
              print("yes1")
                axlHighlightObject(chk)
                println("yes")
  • DavidJHutchins
    Try the modified code shown below, also I don't think you can hightlight cline segments, only it's net...
    let((a in1 cseg1 cseg2 cseg3 cseg4 val data _AirGap loc1 loc2)
    (a = list())
    (in1 = infile("Netlist.lst"))
    when(cseg1
    push(cseg1 a)
    close(in1)
    (cseg2 = car(axlSelectByName("NET", car(a))))
    if(cseg2 then
    axlClearSelSet()
    axlSetFindFilter(?enabled '("NOALL" "CLINESEGS") ?onButtons '("CLINESEGS"))
    val = atof(axlUIPrompt("Enter the minimum airgap :"))
    if(cseg3 then
    foreach(cseg2b cseg2->branches
    foreach(chk cseg2b->children
    (cseg4 = setof(seg cseg3 ((seg->layer) == chk->layer)))
    foreach(cseg5 cseg4
    if(neq(cseg5->net cseg2) then
    when(data
    when(val > _AirGap axlShowObject(cseg5))
    when(_AirGap < val
    (loc1 = car(data))
    (loc2 = cadr(data))
    axlMsgPut("AirGap Spacing error := layer %s; loc1 = %.4f:%.4f ; loc2 = %.4f:%.4f ; airgap %f" cseg5->layer car(loc1) cadr(loc1) car(loc2) cadr(loc2) _AirGap)
    axlHighlightObject(chk->net)
    axlHighlightObject(cseg5->net)
    else
    axlMsgPut("Nothing selected")
