  3. Passing Values in axlSelectByName from infile
  • Views 15513
vimaldevlpr
vimaldevlpr over 6 years ago
I need one help from passing values  infile data to axlSelectByName  its not passing it show me nil can anyone please help me out I'll share my code below.
code:
procedure(clineAirgap()
in1 = infile("Netlist.lst")
a = nil
  while(gets(cseg1 in1)
  a = sort(cons(cseg1 a) ' nil)
  close(in1)
      cseg2 = axlSelectByName("NET", a)
  if(cseg2 then
   axlSetFindFilter(?enabled `("NOALL" "CLINESEGS") ?onButtons `("CLINESEGS"))
   cseg3 = axlGetSelSet(axlAddSelectAll())
   val = atoi(axlUIPrompt("Enter the minimum airgap :"))
   if(cseg3 then
    foreach(cseg4 cseg2
      println(cseg4 ->net ->name)
     when(cseg4->objType == "path"
      foreach(cseg6 cseg4->segments
       foreach(cseg5 cseg3
        when(equal(cseg6->layer cseg5->layer)
         (data = (axlAirGap cseg6 cseg5 (cseg5->layer)))
          when(data
           (_AirGap = (lastelem data))
            if(val > _AirGap  then
             axlHighlightObject(cseg6)
             println("yes")
  • B Bruekers
    B Bruekers over 6 years ago
    Do you have an example of the "Netlist.lst" data file? If it contains a list of netnames then you need to do something like this to read all the lines:
      cseg1 = car(parseString(cseg1 "\n"))
      when(cseg1 push(cseg1 a))
    The parseString is needed to get rid of the newlines which are possibly in the "Netlist.lst" file.
    Further i would not use a sort with each line read. It is better to sort the list at the moment that you are done with reading the complete file.
  • vimaldevlpr
    vimaldevlpr over 6 years ago in reply to B Bruekers
    Kindly thanks for your reply.. values passing fine but while checking in airgap its shows me nil. I want to check the input cline segment with every cline segment present in the board following code attached below could you please check it.
    a = nil
      close(in1)
      if(cseg2 then
       axlClearSelSet()
       if(cseg3 then
        foreach(cseg4 cseg2 ->branches
         foreach(chk cseg4 ->children
         when(chk->objType == "path"
          foreach(cseg6 chk
           println("yes1")
           foreach(cseg5 cseg3
             (data = (axlAirGap cseg6 cseg5 (cseg6->layer)))
              when(data
                 println("yes")
