  3. Find by Query - Vias of certain nets
  • Views 7435
LouShay
LouShay over 6 years ago
Hi, I’m trying to select Vias of a certain Padstack Name, AND belongs to certain nets. It appears the Query function cannot AND two Object types.  Am I missing it?
User story: I have a design with two different via padstacks used throughout. Now I want to change all vias not used for power/gnd to the smaller via.
Thanks for any help you can provide.
The result of this Query selects all VIA2010's on the design. Not just those on the listed nets.
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    With 17.4 S007 I got the query to work in 'show element', however in 'replace padstacks' the 'find by query' is not enabled
    below is the relevant section of the *.qfnd' file:
    *Objects filtered
    "Type" "Vias"
    *Find Filters
    "Filter" "Via"
    "Filter" "AND" "Padstack Name" "equal to" "V_C20P10C26TP_PASTE_TRIAD,C26_WPASTE" "Vias" " " "0" "0"
    "Filter" "AND" "Net" "equal to" "GND,3P3V,3P3V_AUX" "Vias" " " "0" "1"
  • LouShay
    LouShay over 6 years ago in reply to DavidJHutchins
    Thanks for the feedback David. I appreciate your time and effort.     I should have specified version 17.2.
    I'm not sure about 'show element' versus 'replace padstack'. Isn't the Query function independent of a command?
  • mcatramb91
    mcatramb91 over 6 years ago in reply to LouShay
    It looks like you have the Query worked out with David's help, needed to stay within the Via Object Type and query by Padstack and Net Names.
    You can use Find By Query to select all the Vias on the canvas that are not power/gnd then replace the padstack right on the canvas.
    • Open Find By Query and Load Query
    • RMB > Select All on the Find By Query results spreadsheet to select the Vias on the canvas
    • Hover over one of the selected Vias on the canvas and use RMB > Replace padstack > Selected instance(s)
    • Select the padstack to use for the replacement and Click OK
    Hope this helps,
    Mike Catrambone
  • LouShay
    LouShay over 6 years ago in reply to mcatramb91
    Well now I have Mike. Maybe I needed a good nights rest. I was trying to AND two different Objects until I finally saw Net and Padstack Name in the Fields list. So selecting the Padstack Name and Net Fields will automatically AND the query.
