  3. Does OrCAD 17.4 Still Support Back Annotate from PADS Layout...
  • Replies 11
  • Subscribers 167
  • Views 22895
Does OrCAD 17.4 Still Support Back Annotate from PADS Layout?
ZETA1234
ZETA1234 over 6 years ago
There used to be an option to back annotate from a Layout now it is only PCB Editor. I created a .swp file, I would just like to back annotate from that file. Please help.
  • DavidH172
    DavidH172 over 5 years ago
    I am also having the same problem.  In OrCAD 17.2, there is a Layout tab in the Backannotate dialog that allows a swap file to be applied.  This tab is missing in 17.4.  The Design Sync doesn't update reference designators.  That means you can't finish a design if you have uninstalled version 17.2!
