  3. Making a component with only one power pin displayed but...
  • Subscribers 166
  • Views 15197
Making a component with only one power pin displayed but connected to several ball of BGA
vincentAEM
vincentAEM over 6 years ago
I'm pretty new to Cadence allegro and i'm facing a new problem.
I am creating a LTM4630 component from analog device and there are several power pins connected together.
In the datasheet, the component is designed with only 1 pin for VIN for example, and this pin is in fact several balls of the BGA.
I would like to make the same representation of the component, and having only 1 VIN pin on my design, but corresponding to multiples of the BGA, is this possible?
Thanks in advance,
Vincent
  • RFinley
    RFinley over 6 years ago
    split the library symbol into two heterogeneous instances.  One having the signal/power pins you do want to show, the other having power/gnd pins you want to hide on the "back pages."
  • stumpsr1019
    stumpsr1019 over 6 years ago
    Isn't this just a block diagram showing the part and not a real representation of what the schematic symbol should look like? Wouldn't you want to see all of the VIN power pins on the logic? Just make the signal name be VIN_(Pin number) for each VIN pin and change the text on the symbols (not the pin name) for each pin to be VIN. Then group them together.
  • stumpsr1019
    Hi Vincent, wondering how you ended up handling this?
