  3. Problem in step file mapping
  • Views 15630
ecycv71
ecycv71 over 6 years ago
I tried to map a step file in the PCB editor (ver17.2-2016) and encountering an error as  attached. Pl help on this.
  • AvengerThanos
    AvengerThanos over 6 years ago +1
    It isn't any error...you can click on OK and still continue.. Add the step path again under the path in user preferences that might help you
  • AvengerThanos
  • ecycv71
    ecycv71 over 6 years ago in reply to AvengerThanos
    Thanks, I tried a different step it works.
