  3. axlSingleSelectBox on one layer only
  • Views 15465
leto
leto over 6 years ago
Hello All,
May I know if it is possible to use
axlSingleSelectBox( list(6200:3700 6500:3300))
on just a single layer?
Currently it appears to select from all the visible layers.
If i just want to select traces from one layer, I will have to switch off the other layers.
Thanks All
  • luanvn81
    luanvn81 over 6 years ago +1
    Hi leto! I suggest you can use "setof" command to filter the traces on one single layer. I think that is best simple way. Luan.
  • luanvn81
    Hi leto!
    Luan.
  • leto
    leto over 6 years ago in reply to luanvn81
    Hello Luan,
    Yes that will work!!! I just need to filter out dbids with from different layers.
    Leto
