  3. Allegro impedance calculation
  • Subscribers 166
  • Views 21585
Sulmaz
Sulmaz over 6 years ago
I have an issue with Allegro calculating the impedances. I have followed this tutorial: https://www.youtube.com/watch?v=XKVQPEIeRT0 but I am getting wrong values. Even if I put same values for cross section as he has in 0:40, mine values for trace thickness with same impedances (and vice versa) are approx. 40 times bigger: https://imgur.com/a/5ktfCpb.
I am assuming there is another settings somewhere which influence this but I am not able to find it. Can someone please help me with this problem?
Thank you in advance.
I am using OrCAD PCB Designer Professional 16.6-2015 S060
  • redwire
    redwire over 6 years ago +1
    You are not properly marking the reference plane as "PLANE", instead you are marking all layers as "CONDUCTOR". The Allegro tool is as accurate as any tool in the market -- just set it up correctly.
  • Sulmaz
    Sulmaz over 6 years ago +1
    Thank you so much guys! I never doubted Allegro, I just did not know what I set wrong. Now everything works flawlessly!
  • Wild
    Wild over 6 years ago
    So which layer is your plane?
  • redwire
  • Sulmaz
