  3. difference between solderpaste_top vs pastemask_top
  • Views 14495
frank mpbc
frank mpbc over 6 years ago
In the pad editor, I see the word "pastemask_top" for the steel sheet stencils for the solderpaste.When I open a .dra in Allegro, I see in the color dialog both pastemask_top and solderpaste_top.  I don't see solderpaste_top in the pad editor.
What is the solderpaste_top?
Frank
  • DavidJHutchins
    DavidJHutchins over 6 years ago +1
    With the .dra open in Allegro, try using Setup>Subclasses... to see if 'solderpaste_top' is a user-defined subclass, I don't see it in any of the .dra's I just openned...
  • DavidJHutchins
  • frank mpbc
    frank mpbc over 6 years ago in reply to DavidJHutchins
    It is in a .dra I got from Ultralibrarian.com.
    I posted the output of setup->subclasses.
  • frank mpbc
    frank mpbc over 6 years ago in reply to frank mpbc
    I opened two.dra files that were generated from the Wizard. They do not have solderpaste_top. I put a screen capture of the color dialog below.
    The file from ultralibrarian is to make this stencil and footprint for a Texas Instruments chip:
