  3. skill fails for 3d
  • Views 13997
skill fails for 3d
digital1
digital1 over 6 years ago
Hi all i created a script to highlight a net and then all components attached to that net however when i do a 3d command the highlights are deselected
ive broken it down to a small script that can be run in the script interpreter by typing set telskill
the commands that i have broken the problem down is
axlSetFindFilter(?enabled list("noall" "nets") ?onButtons list("noall" "nets"))                  ;for this example im only interested in nets
net1 = car(axlUIDataBrowse('NET '( RETRIEVE_NAME) "Select NetName" t))            ;here i select what net im interested in
axlGetSelSet(axlSingleSelectName( "NET" net1 ))                                                        ;this command highlights it in pcb editor
axlShell "3d"        ;this should generate a 3d representation of my highlighted net  but it dehighlights the net
Can anyone shed any light where im going wrong
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    your script only selects the net, you need to add an additional command to actually highlight it, for example:
    (axlHighlightObject car(axlGetSelSet()) nil)
    However from what I can see from what little I can I have used '3d', it doesn't appear to support highlighting of existing highlighted objects
  • digital1
    digital1 over 6 years ago in reply to DavidJHutchins
    Sorry davidJHutchins  but the 3rd line down on my simple script (this is taken from a larger script but shortened here to show what is broken in as short a script as possible) the line saying axlGetSelSet(axlSingleSelectName( "NET" net1 )) highlights the net.
    I also tried it your way and it still doesnt work
    The full script is running in a gui and what it does is select the net and all the components hanging from that net and then does a 3d representation
