  3. Via Overlapp
  • Views 13006
Via Overlapp
vimaldevlpr
vimaldevlpr over 6 years ago
Already Developed skill code via overlapped by via it checks only the through hole via in between layer's blind and buried vias if overlaps means its not showing I will attach the code below can anyone please update finding blind and buried vias if they overlapped.
defun( getDuplicateHoles (@optional netName)
 let((oldSetData, holeObjects)
  oldSetData = list(axlGetSelSet(), axlGetFindFilter(nil), axlGetFindFilter(t))
  axlClearSelSet()
  axlSetFindFilter(?enabled '("noall", "pins", "vias", "invisible"), ?onButtons '("noall", "pins", "vias"))
  axlAddSelectAll()
  holeObjects = setof(obj, axlGetSelSet(), obj ->isThrough)
  when(netName, holeObjects = setof(obj, holeObjects, obj ->net ->name == upperCase(netName)))
  axlSetFindFilter(?enabled cons("noall", cadr(oldSetData)) ?onButtons cons("noall", caddr(oldSetData)))
  axlSingleSelectObject(car(oldSetData))
  getDuplicateObjects(holeObjects)
defun( getDuplicateObjects (objs @key (tol axlMKSConvert(0.2 "mm")))
 let((obj, loc, closeObjs, dupes, p)
  while(objs
    obj = car(objs), objs = cdr(objs), loc = obj ->xy
    closeObjs = setof(o, objs, and((car(o ->startEnd) == car(obj ->startEnd) || cadr(o ->startEnd) == cadr(obj ->startEnd)), samePoint(o ->xy, loc, tol)))
    when(closeObjs
      dupes = cons(sprintf(nil, "%s at %L %s %s clashes with %s at %L", axlPPrint(obj ->objType), obj ->xy, car(obj->startEnd), cadr(obj->startEnd), buildString(unique(closeObjs ~>objType), ", "), closeObjs ~>xy), dupes)
  if(dupes then
    p = axlDMOpenFile("MISC", "duplicateHoles.txt", "w")
    fprintf(p, "Duplicate holes:\n\n")
    foreach(dupe, dupes, fprintf(p, "%s.\n", dupe))
    axlDMClose(p)
    axlUIViewFileCreate("duplicateHoles.txt", "Duplicate holes", nil)
   else
    println("No duplicates found.")
  dupes
defun( same (x1, x2 @optional tolp, tolm)
  unless(tolp, tolp = expt(10, -2 - cadr(axlDBGetDesignUnits())))
  cond(
    (!x1 && !x2, t); Both are nil
    (!x1 || !x2, nil) ; One, and only one, is nil
    (!tolm && abs(x1 - x2) > tolp, nil)
    (tolm && x1 - x2 > tolp, nil)
    (tolm && x2 - x1 > tolm, nil)
    (t, t)
defun( samePoint (pt1, pt2, @optional tolp, tolm)
  and(same(car(pt1), car(pt2), tolp, tolm), same(cadr(pt1), cadr(pt2), tolp, tolm))
