  3. Select all of Cline at one point
  • Views 16258
ichliebedich
ichliebedich over 6 years ago
Hi All!
I want to select all Cline at one point,
for instance, there are Clines at one Via, but I can't use axlDBGetConnect function,
because one of Cline is apart from via like below pic.
so I thought if I know the one point coordinate then, I could find all of Clines at there.
I tried to multiple check at one point with axlSingleSelectPoint() function.
but it only can select 2 Clines alternatively (toggle select)
is there any good tips & tricks or functions?
regard,
  • ichliebedich
    I solved this problem! just use axlAddSelectPoint() iteratively, then it will select multi elements
