  3. 3D. Board not visible
  • State Verified Answer
  • Replies 7
  • Subscribers 169
  • Views 23176
JuriV
JuriV over 6 years ago
Hello everybody,
I have a problem by using of 3D canvas. I can see the components only, but not the PCB self. In the visibility windows all  is checked. Are any variables must be set in the User Preferences? I am using 17.4 with HotFix 10. Every body know this issue?
Thank you
  • JB Silverstone
    JB Silverstone over 4 years ago +2 verified
    Check you don't have a shape in the Class:Board Geometry:Cutout layer. This caused the same problem to us. Once we removed the cutout the board re-appeared.
  • steve
    0 steve over 6 years ago
    Check to make sure that the board outline is drawn using the class/subclass Board_Geometry / Design_Outline. If you have used the old outline subclass this won't work for the 3d view.
  • JuriV
    0 JuriV over 6 years ago in reply to steve
    Thank you Steve,
    the board outline is Design Outline.
  • redwire
    0 redwire over 6 years ago
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/27/6175.irr_5F00_outline_5F00_stripped.zip
    Should be no issue if the outline is on the design outline layer as Steve said.  Please take a look at this example and paste a screenshot from the 3D viewer.  Make sure you select "ALL OBJECTS" when the 3D viewer prompts you otherwise the 3D canvas will be blank!
  • JuriV
    0 JuriV over 6 years ago in reply to redwire
    Thank you very much,
    in fact the issue on my current design only. Another designs work better. I have to investigate this issue again.
    Thank you again
  • kkosin
    0 kkosin over 5 years ago in reply to JuriV
    If you happen to have the board outline in Class: Board Geometry, Subclass: Ncroute_path the board will not show up in 3D canvas.  This is also true if you have the board outline in subclass: Cutout.
