  3. Impossible to import constraints file with 17.4
  • Views 16949
Tinkerman
Tinkerman over 6 years ago
Hi all,
I try to export-import design constraints file.
Export goes well.
When I try to import I get:
Error: schemaLocation does not contain namespace-location pairs (l:2; c:92)
             Section read operation aborted
What's wrong?
  • Tinkerman
    Nobody knows? Anyone uses this functionality at all?
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    You didn't supply enough detail to allow anyone to fully understand your issue...
    What tool were you using - pcb editor or schematic editor
    what is your exact tool version?
  • Tinkerman
    Tinkerman over 6 years ago in reply to DavidJHutchins
    PCB Editor, 17.4HF10.
  • DavidJHutchins
    I went thru this process a couple of days ago with a couple of designs without any issues, however I'm running a slightly older release 17.4 S008
    The export:
    \i (00:00:16) cmgr
    \i (00:00:18) generaledit
    \i (00:00:26) QtSignal menuFile menuExport Triggered Constraints...
    \i (00:00:31) QtSignal groupBox_2 radioBtn_DesignSpecific toggled off
    \i (00:00:31) QtSignal groupBox_2 radioBtn_Generic toggled on
    \i (00:00:31) QtSignal groupBox_2 radioBtn_Generic clicked on
    \i (00:00:38) QtSignal BaseFileDlgWithScope AQFileDialog finished 1
    \i (00:00:38) QtFillin D:/SPB_Data/cust10/Design22/Design10_XY_Mezz_111419a.dcfx
    \i (00:00:38) QtFillin ReportPath D:/SPB_Data/cust10/Design22/Report.xml
    \i (00:00:38) QtSignal m_menuBar menuFile Triggered Constraints...
    \i (00:00:43) QtSignal m_menuBar menuFile Triggered Close
    The import:
    \i (00:01:25) cmgr
    \i (00:01:25) QtSignal m_dockWsQtWidgetContents m_domainSelector currentChanged
    \i (00:01:25) QtSignal m_dockWsQtWidgetContents m_domainSelector currentChanged Electrical
    \i (00:01:26) generaledit
    \i (00:01:34) QtSignal menuFile menuImport Triggered Constraints...
    \i (00:01:43) QtSignal frame_2 ImportReportOnly clicked false
    \i (00:01:52) QtSignal BaseFileDlgWithScope AQFileDialog finished 1
    \i (00:01:52) QtFillin D:/SPB_Data/cust10/Design22/Design10_XY_Mezz_111419a.dcfx
    \i (00:01:52) QtFillin ReportPath D:/SPB_Data/cust10/Design22/Report.xml
    \t (00:01:55) Performing DRC...
    \t (00:01:55) Multithreaded DRC update (8 threads).
    \t (00:01:56) DRC done; 438 errors detected.
    \i (00:01:58) QtSignal m_menuBar menuFile Triggered Constraints...
    \i (00:02:04) QtSignal MainWindow ReportViewerDlg closed
    \i (00:02:07) QtSignal m_menuBar menuFile Triggered Close
  • Tinkerman
    Thank you David. I finally nailed it. The problem was that my installation folder contained a space symbol. This thread helped to investigate it. I don't know if it is Cadence or Microsoft related problem but now it is solved.
