  3. Problem generating PDF of Assembly Drawing
  • Views 18273
jatins
jatins over 6 years ago
Hi
I am trying to export assembly drawing of my layout with Package Geometry>Ass Top and Components>Ref DES Options.
But i cannot manage to change the page layout to Landscape mode. I have tried several options including:
Print Preview> Layout. Nothing happens after i press Layout.
If i choose Print Preview> Print. Even after i choose Landscape Mode it prints out pdf in Portrait mode.
 It has worked before well but after a hotfix update this issue started.
  • jatins
    Hi
    Update: Now i tried to make pdf with Export>pdf option.
    And it only works with Assembly Top Layer. Not for Bottom Layer as there is no option for mirroring the display (as it was in Print Setup Option).
  • steve
    steve over 6 years ago in reply to jatins
    So this is controlled by the artwork film. Go to Export - Gerber and select the Bottom film name and then enable Film mirrored. This is then used on Gerber export and PDF export.
  • RMBeatriz
    RMBeatriz over 5 years ago in reply to steve
    I have a similar problem. I am trying to export to pdf but I cannot obtain a black and white mode. Instead a grey scale image of layout is gotten. How I get a layout image in real black and white mode only?
  • jc teyssier
    jc teyssier over 5 years ago in reply to RMBeatriz
    File->plot setup: here is present a mark for black and white outpout
  • steve
    steve over 5 years ago in reply to RMBeatriz
    There is a checkbox in the Export PDF form that will output the PDF in Black and White.
