  3. How to extract the pin's layer information from DBID?
  • Views 3601
ichliebedich
ichliebedich over 6 years ago
Hi all,
How can I extract the pin's layer information?
in case of vias, shapes, their have "layer" data so we can extract the layer information easily.
however, there was no any data for pin.
I wrote code for instance below:
axlClearSelSet()
axlSetFindFilter(?enabled `("NOALL" "VIAS") ?onButtons `("NOALL" "VIAS"))
axlAddSelectAll()
vias_dbid = axlGetSelSet()
axlClearSelSet()
; check number of elements which connected with via
(foreach each_via_dbid vias_dbid
  elm_dbid = axlDBGetConnect(each_via_dbid t)
  println(elm_dbid)
; check the types of elements
  (foreach each_elm_dbid elm_dbid
  println(each_elm_dbid->objType)
  );2nd foreach cloese
);1st foreach close
then, the result was,
there were 3 "path" and 1 "pin" as you can see,
I can extract the path layer using ' each_elm_dbid->layer ' in my function for 'path' type
but I can't extract the pin's layer using that function.
How can I get the layer information of pins?
regards,
  • luanvn81
    luanvn81 over 6 years ago
    Hi!
     you can try this:
     if(each_elm_dbid->objType == "pin" then
         println(each_elm_dbid->startEnd)
    );end if
    Luan.
  • ichliebedich
    ichliebedich over 6 years ago in reply to luanvn81
    I really appreciate! it's that I want
