  3. How to convert to Design_Outline(latest ver.) from Outline...
  • Subscribers 166
  • Views 3800
How to convert to Design_Outline(latest ver.) from Outline (16.x ver.) on SPB 17.4 ?
ichliebedich
ichliebedich over 6 years ago
Hi all.
I imported one of brd file which created by SPB16.x ver. at SPB17.4
but I had issue to converting Outline to Design_Outline at Board_Geometry class
as I know, I normally used the 'Change to layer' to convert other layer.
but as you can see, there is no any 'Design_Outline' class (see below pic.)
How to convert from 'OUTLINE' to 'Design_Outline' ?
regards,
  • steve
    steve over 6 years ago
    A Design_Outline must be a closed shape so try Shape - Compose Shape (or Create Shape from Lines), check the Options pane for Class/Subclass and then window the board.
  • CadAce2K
    CadAce2K over 6 years ago
    If Outline is completely closed (all vertexs meet), then you can use Edit/Z-Copy and set subclass to Geom/Design_Outline and zero as the compress/expand, and it will create you Design_Outline.
