  3. How to determine if SILKSCREEN_TOP REFDES is visible
  • Views 15153
redwire
redwire over 6 years ago
Hi
I'm working my way thru SKILL and can find all my components.  I then look at the component symbol to find its children from which I find SILKSCREEN_TOP
However, I don't know how to determine if it's visible or not.  This is a result from a command line query on the dbid which I have assigned to "cmpChild":
cmpChild->??
(prop nil bBox
((5.8492 16.1326)
(6.5508 17.3008)
) readOnly
t objType "text" layer "PACKAGE GEOMETRY/SILKSCREEN_TOP"
xy
(5.9 16.45) text "2" textBlock
"2" rotation 0.0 parent dbid:00000000429AF9F8
mirrorType "NO" isMirrored nil justify
"LEFT" parentGroups nil
Is there an easy way to determine if I have deleted the ref des or not?  In this case, I have deleted it but I can't find the property which tells me it's been deleted.
Bill
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    hopefully the code below will help you figure this issue out, I wrote this to flag components with missing refdes silkcreen text ( cap, res & ferrite beads are excluded )
    procedure((check_missing_silk)
    let(( layerName errcnt RefList dbid Class )
    (errcnt = 0)
    (layerName = "REF DES/SILKSCREEN_")
    (RefList = setof(sym, axlDBGetDesign()->symbols, sym->refdes && !exists(obj, sym->children, obj->text == sym->refdes && index(obj->layer, layerName)))~>refdes)
    foreach(ref RefList
    rexCompile("^[CR][0-9]")
    unless( rexExecute(ref)
    unless(rexMatchp("^FB[0-9]" ref)
    (axlClearSelSet)
    (axlSetFindFilter ?enabled list("noall" "symbols" "invisible") ?onButtons list("noall" "symbols"))
    (dbid = car(axlGetSelSet(axlAddSelectName("SYMBOL" ref))))
    when(dbid
    if(dbid->isMirrored then
    (Class = "DRC ERROR CLASS/PACKAGE_BOTTOM")
    else
    (Class = "DRC ERROR CLASS/PACKAGE_TOP")
    (dbid = axlDBCreateExternalDRC("missing silkscreen refdes" (dbid->xy) Class list(dbid) nil nil))
    when(dbid
    (errcnt++)
    axlMsgPut("%d violations found" errcnt)
  • redwire
    redwire over 6 years ago in reply to DavidJHutchins
    Oh, that is beautiful!  You just taught me at least 6 new tricks in SKILL.  Thank you Jedi master!
  • DavidJHutchins
    DavidJHutchins over 6 years ago in reply to redwire
    Gald to help, I'm not a master, that's reserved for Dave Elder & FXF
    I got the setof() usage from some of Dave's code...
