  3. Symphony tools issue
  • Subscribers 167
  • Views 14972
rhiannonb1997
rhiannonb1997 over 6 years ago
My company have some custom tools in the menu in PCB Editor 17.2 but when we use Symphony option, our custom tools disappeared from the menu.
I don't know what I'm suppose to do.
Thank's
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    After looking at the menu files in %CDSROOT%/share/pcb/text/cuimenus I think you may need to add your menu files to allegro_mu.men in addition to allegro.men
    This is jus a guess since I can't test it...
  • mcatramb91
    mcatramb91 over 6 years ago
    A couple of things. :-)
    If your company has a custom tools menu they really should be dynamically adding it to Allegro using SKILL.  This will avoid having an "out-of-date" menu file when new functionality is added.
    I had a couple of posts over the years to setup dynamic menus in Allegro but there is a nice blog post on the subject that explains the process, I would recommend dynamic custom menu vs. static menu updates:
    BoardSurfers: Make Menus Your Own – Customizing Menus and Toolbars with Things You Use Daily
    As far as Symphony, if the items in the Custom Tools menu are running SKILL Routines they will need to be revised to be used in Symphony.
    There is a guide to step thru the process of tweaking the SKILL Code:
    Symphony SKILL Development Guide
    Hope this helps,
    Mike Catrambone
