  3. copy 'Line' with offset from 'Shape' type
  • Subscribers 160
  • Views 2456
ichliebedich
ichliebedich over 5 years ago
Hi all,
I want copy the 'Ncroute_path' which included in 'Board Geomety' property from 'OUTLINE' class which consist of 'Shape' type as an 'Line' type with offset along the outline.
for instance, there was the 'OUTLINE' (pointed blue arrow), and I want to create the 'Ncroute_path' (pointed by red arrow) along the outline with contact and smoothly following the contour
upper pic is not that I want to make, so how can I correct that line?
  • jc teyssier
    jc teyssier over 5 years ago
    here is how i do this:
    - zcopy shape from outline to NC_T+ROUTE_PATH ising half of tool cutting width
    - decompose the resulting shape on same layer
    -change reslting line wdth to tool cuttin witdth
    That's all Slight smile
  • ichliebedich
    ichliebedich over 5 years ago in reply to jc teyssier
    thank you! I used the 'shape' - 'Create Lines from Shape' !
