  3. DRC error after EMI shield placement
  • Views 13469
HotrodJEB
HotrodJEB over 6 years ago
I am still learning here so, please be patience with me.
I had no DRC errors until I placed the EMI shield. I believe the issue is related to the height of the shield.
I did not create this component so, how do I change the component height?
Would I also need to set a min and max component height?
(PCB Editor, 17.4-2019 S009 [8/4/2020] Windows SPB 64-bit Edition)
  • steve
    steve over 6 years ago
    The shield will more than likely have a shape on PLACE_BOUND_TOP or _BOTTOM so try Setup - Areas - Package Height (or Outline - Package Height if you have an OrCAD License) then select the shape and look at the Options pane. This pdf may also help:- www.parallel-systems.co.uk/.../Height_definition.pdf
  • HotrodJEB
    That corrected the issue.
    Thank you for the advice.
