  3. solder mask missing on some components
  • Replies 8
  • Views 20518
HotrodJEB
HotrodJEB over 6 years ago
After generating my gerbers, the board house is telling me solder masks are missing on several components.
Here are the screenshots for top and bottom layers where mask openings are missing from all major components holes, PTH holes, SMT pads.
How do I correct?
Top
Bottom
  • steve
    steve over 6 years ago in reply to HotrodJEB
    Almost but the Modify Library Padstack only opens the library defined pad (so if you have a 6 layer design a PTH pin will only show the DEFAULT_INTERNAL layer rather than all 4 internal layer names. When you edit the pads if you want to make a permanent change just use File - Save in Padstack Editor before you update to the design and this will write the library padstack.
  • HotrodJEB
    HotrodJEB over 6 years ago in reply to steve
    They recommending that I unfill the vias.
    They are suggesting I change it to this:(ideally, not a must)
    How do I remove the filled vias? should I since they are isolated from the plane anyways?
    Why are arrows pointing to the connectors? Does that mean they are connected to the plane unintentionally?
  • steve
    Its unlikely to be the plane is connected incorrectly to the via since you would see a DRC error, Are the Shapes Up to Date (Check - Design Status). Sometimes connecting a pin to a large plane directly can be an issue since it can cause solder issues but unusual for a comment on a via. I would ask for an explanation from the fabricator
