  3. solder mask missing on some components
  • Replies 8
  • Views 20517
HotrodJEB
HotrodJEB over 6 years ago
After generating my gerbers, the board house is telling me solder masks are missing on several components.
Here are the screenshots for top and bottom layers where mask openings are missing from all major components holes, PTH holes, SMT pads.
How do I correct?
Top
Bottom
  • HotrodJEB
    I am assuming everything in yellow is correct.
  • steve
    steve over 6 years ago
    So if you use the command Tools - Padstack - Modify Design Padstack then click on one of the pads that is missing mask then right click - Edit, Padstack Editor will launch and you can add a definition for soldermask. Even if you copy the design pad size so it's one for one. Once complete use File - Update to Design and Exit and this then updates the padstack in the board file with a mask definition. Continue working through the pads that need this. The ideal scenario is that you edit the actual library padstack so that next time you use this padstack it has been updated to suit.
  • HotrodJEB
    HotrodJEB over 6 years ago in reply to steve
    Thank you for helping.  New to pcb editor and  I am so confused.
    Some of the items in yellow are components with pads that should not be masked. others are vias that I would think need to be masked.
    Could you briefly explain the problem they are reporting? Components are missing soldermask openings vs solder mask?
  • steve
    steve over 6 years ago in reply to HotrodJEB
    So soldermask is an opening, you define an opening in padstack editor for items that you don't want soldermask on. When you send this to the fabricator he makes a negative of this to create a soldermask film, they then print soldernask on the board leaving your pins clear of soldermask (if that makes sense). Vias - depends, sometimes users want these covered with mask sometimes not, sometimes only one side. You may also need to generate a pastemask (where solder is printed on the pads) for automatic assembly. Hope that helps
  • HotrodJEB
    Thank you for your patience and detailed responses. I believe I am making progress now.
    I was able to make the changes using "Modify Design Padstack".
    So, changes will remain until I use those parts in a new layout?
    Otherwise I should use "Modify Library Padstack" for reuse in other designs? Is that correct?
