  3. Oblong XY report
  • Views 15491
Oblong XY report
karthikeyan123
karthikeyan123 over 6 years ago
hi,
I would like to get oblongs CENTER POINT xy location report I don't know how to get can any one please guide me how to get center of oblongs XY.
  • luanvn81
    luanvn81 over 6 years ago
    Hi!
    You can use  axlDBAltOrigin(g_mode o_dbid )⇒ xy/nil
    g_mode
    The ‘center option returns the body center of an object.
    The‘origin option returns the origin of an object (normally if dbid
        has an xy attribute, this is the same coordinate).
    The‘pin1 option returns pin1 as center.
    Luan.
  • karthikeyan123
    karthikeyan123 over 6 years ago in reply to luanvn81
    Kindly Thanks for the help luan.
  • karthikeyan123
    Hi luan,
    One more doubt please what is command to get layer name and radius value.
    while using by this it shows me nil.
    procedure(check()
    foreach(item axlDBGetShapes("ROUTE KEEPOUT")
      chk = axlDBAltOrigin('center item)
      println(item ->layer)
      println(item ->radius)
  • luanvn81
    luanvn81 over 6 years ago in reply to karthikeyan123
    Hi!
    Try this code:
    procedure(check()
    println(item->layer)
    foreach(el setof(element item->segments element->xy != nil)
    println(el->radius)
    Luan
  • karthikeyan123
    Thanks Luan
