  3. Netlist compare to schematic tool
  • Subscribers 167
  • Views 15320
TheD
TheD over 6 years ago
HI guy's
I'm looking for a toll that i can compare a Netlist to the schematic , currently we do it manually one is going over the net list and other is checking if the schematic is the same
do you familer with a tool that can help with that ?
  • redwire
    redwire over 6 years ago
    Umm...what? why?  What schematic tool are you using?
    OrCAD will sync automatically with Allegro so need to compare. Just do a netlist import into Allegro and see if there are any eco changes.
    If you are using another tool then post up what your process is because there are other means but no need for me to guess.
  • TheD
    TheD over 6 years ago in reply to redwire
    Hi
    sometimes our schematics don't correlate with the net list ( due to Engineer mistake - for example he thought that a net is connected to a pin but actually it doesn't ) . we need this tool just to validate the schematic
  • redwire
    redwire over 6 years ago in reply to TheD
    It's already built in to the Cadence tools.  Just use the tools as designed and you'll be fine.
    If you have *different* tools then post up because there is no way I can guess.
  • luvishis
    luvishis over 5 years ago
    Elgris Technologies (www.elgris.com) has Netlist comparison tool that can compare 2  netlists or a netlist to a schematic. Many formats are supported.
