  3. padstack definition
  • Subscribers 166
  • Views 16436
padstack definition
masamasa
masamasa over 5 years ago
is there a way to define a padstack with multiple vias?
i have one pad with 12 vias.
i would like to define them as one padstack.
  • RFinley
    RFinley over 5 years ago
    Ah, the multi-drill padstack feature.
    One pad, multiple drills.
  • tennywhy
    tennywhy over 5 years ago
    may be you could do it as follow
  • masamasa
    masamasa over 5 years ago in reply to tennywhy
    thank you for your reply.
    i have tried your way but it does not work.
    how can i specify the xy location of the vias within the pad?
    i need to place 12 vias based on our customer's request as shown below.
  • steve
    steve over 5 years ago in reply to masamasa
    If the multiple drills option won't work the only way is to do this in a Package Symbol. Place the main pad down then use Layout - Connections and double click to add a Via. (The chosen via is setup as you would in a board file Constraint Manager - Physical). Once you have a via you copy this and place it at the required co-ordinates as you would normally.
  • tennywhy
    tennywhy over 5 years ago in reply to masamasa
    steve is right.  if you want every one via's x/y locations , as i know,  the only way do this is in package symbol not in pad editor. in package symbol you are free do this. like this.
