  3. TrueDFM constraint modes
  • Views 13764
tshinseki
tshinseki over 5 years ago
Is there a axlCNS get command to find out the constraint modes and values for TrueDFM related checks?
-Troy
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    I doubt that anything has been added after looking at the documentation files in %ccsroot%\share\pcb\examples\skill\DOC\FUNCS\,, no new axlCNS* doc files since 05/01/2016
  • tshinseki
    tshinseki over 5 years ago in reply to DavidJHutchins
    That's unfortunate..., thanks for looking David!
    -Troy
  • Ejlersen
    Ejlersen over 5 years ago
    Hi Troy
    They are indeed available if you look in the online documentation.
    In PCB Editor select Help -> Documentation and do a search for axlCNSDesignModeGet
    This will direct you to the correct location.
    Notice that in the past function descriptions within the folder that David refers to was most recent. With 17.4 the online documentation is more up to date than the folder refered.
    Best regards
    Ole
