  3. Component placement -Draw Rectangle
  • Views 7126
KARTHIK RANGARAJ
KARTHIK RANGARAJ over 5 years ago
Hi All
My Requirement is  when I select the parts from  Schematic (Capture CIS) ,in Allegro PCB editor  I draw rectangle all selected parts placed within the rectangle.
I know room option already available. But i am looking for without disturbing schematic .
Karthik.R
  • joma
    joma over 5 years ago
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/st_5F00_group_5F00_comps_5F00_v1_2D00_0.zip
    Hi Karthik,
    I had been meaning to write a script for grouping components for years. I finally got round to it. The attached skill file will group selected
    components if they are already placed on the canvas. I use quickplace first. The components will keep to the rectangle unless there are
    too many in which case they will overlap the bottom of the rectangle. This is a relatively simple script which suits my purposes. I imagine
    that there are various improvements that could be made such as spacing options, warnings if fixed objects are found, placement of
    non-placed comps etc etc. I will not be creating any updates in the near future as my job is pcb routing not programming or sys-admin
    but if anyone wants to add to or improve the code please feel free to do so.
    Jim O'Mahony
  • KARTHIK RANGARAJ
    KARTHIK RANGARAJ over 5 years ago in reply to joma
    Thanks Joma. It was working fine as per my requirements. thanks for your support
