  3. Via Overlap
  • Views 17163
Via Overlap
karthikeyan123
karthikeyan123 over 5 years ago
I am having one via overlapped code but while running it shows error can any one correct the code and send me back please.
procedure(viaovrlapp()
via_overlay = list()
layername = nil
etchparam = axlGetParam("paramLayerGroup:ETCH")
layername = etchparam->groupMembers
print(layername)
axlSetFindFilter(?enabled `("NOALL") ?onButtons `("NOALL"))
axlSetFindFilter(?enabled `("NOALL" "ALLTYPES") ?onButtons `("vias"))
foreach(1name layername
 print("a")
 if(axlDBGetLayerType(sprintf(nil, "ETCH/%s", 1name)) == "CONDUCTOR" then
  axlVisibleDesign(nil)
  axlVisibleLayer(sprintf(nil, "VIA CLASS/%s"), 1name)
  axlAddSelectAll()
  objs = axlGetSelSet()
  axlClearSelSet()
  foreach(obj_via objs
   print("b")
   if(axlSingleSelectBox(obj_via -> bBox) then
    area_via = axlGetSelSet()
    axlClearSelSet()
    via_pad = axlDBGetPad(obj_via sprintf(nil "CONDUCTOR/%s" 1name) "REGULAR")
    via_padstack = via_pad ->bBox
    o_radius = abs(car(nth(0 via_padstack)) - car(nth(1 via_padstack))) / 2.0
    if(length(area_via) > 1 then
     foreach(a_via area_via
      print("c")
      via_pad = axlDBGetPad(a_via sprintf(nil "CONDUCTOR/%s" 1name) "REGULAR")
      a_radius = abs(car(nth(0 via_padstack)) - car(nth(1 via_padstack))) / 2.0
      wid = o_radius + a_radius
      gap = abs(axlDistance(obj_via -> xy , a_via -> xy))
      wid = round(wid = 1000) / 1000.0
      gap = round(gap = 1000) / 1000.0
        if(gap > 0.001 && gap < wid then
         airgap = nth(2 axlAirGap(obj_via a_via 1name nil))
         if(airgap == 0.0 then
          via_overlay = append(via_overlay list(1name, obj_via ->xy))
          print(via_overlay)
  • luanvn81
    luanvn81 over 5 years ago
    Hi!
    You can test this code, but I think this code need more repair.
    if(member("ETCH" axlClasses()) != nil then class_chk = "ETCH" else class_chk = "CONDUCTOR");end if
    layername = nil
    axlSetFindFilter(?enabled `("NOALL" "VIAS") ?onButtons `("VIAS"))
    foreach(layer_id layername
    if(axlDBGetLayerType(strcat("ETCH/", layer_id)) == "CONDUCTOR" then
    axlVisibleLayer(strcat("VIA CLASS/", layer_id) t)
    axlAddSelectAll()
    axlClearSelSet()
    area_via = axlGetSelSet(axlSingleSelectBox(obj_via->bBox))
    axlClearSelSet()
    via_pad = axlDBGetPad(obj_via strcat(class_chk "/" layer_id) "REGULAR")
    via_padstack = via_pad->bBox
    o_radius = abs(car(nth(0 via_padstack)) - car(nth(1 via_padstack)))/2.0
    via_pad = axlDBGetPad(a_via strcat(class_chk "/" layer_id) "REGULAR")
    a_radius = abs(car(nth(0 via_padstack)) - car(nth(1 via_padstack)))/2.0
    gap = axlDistance(obj_via -> xy , a_via -> xy)
    via_overlay = append(via_overlay list(layer_id, obj_via ->xy))
    printf("%L\n", via_overlay)
  • karthikeyan123
    karthikeyan123 over 5 years ago in reply to luanvn81
    thanks a lott
