  3. Report showing net , physical class name.
  • Replies 7
  • Views 16334
Lennie
Lennie over 5 years ago
I want to generate a report with net-name , physical class , and group class.
I can get the group glass but cannot physical class.
Is that possible  ?
  • steve
    steve over 5 years ago
    Yes it's possible. Tools - Reports - New/Edit and add NET_NAME and NET_NAME_SORT from the Data Fields tab, NONE_PHYSICAL_CONSTRAINT_SET from Properties tab and NETCLASS_GRP_NAME from the Miscellaneous tab. Save the report and run it.
  • Lennie
    Lennie over 5 years ago in reply to steve
    Thanks . I will try that shortly. Is that documented anywhere or is it just trial and error  ?
  • steve
    steve over 5 years ago in reply to Lennie
    You can generate a report of pretty much anything using this method. It uses the Extracta command which you can find info on using Cadence online support. Sometimes It's obvious, other times it's a bit of trial and error.
  • Lennie
    Unfortunately that did not work.  it shows the net name , The physical constraint set name, but for  Netclass_GRP_NAME , if the net is in both a class in electrcial and physical class it shows the electrical class name. I want to show a net and the class name from both electrical and physical class.
  • Lennie
    When Using  NET_CLASS_GROUP_NAME in a report, if you have a net in a physical Class and the same net in an electrical class the software lists the electrical class. I need to be able to list the class name for both the electrical and physical. is there another variable that can be used ?
