  3. Flex zone slide arc
  • Views 13227
Flex zone slide arc
Lennie
Lennie over 5 years ago
Since you can only use the shape edit to edit a flex zone shape, how do you slide an ARC ? Or change the ARC to a right angle  ?
  • steve
    steve over 5 years ago
    Hover over the arc in question and right click - Remove Extend Segments to change it to a right angle, set the required radius in the Options pane then click on the corner to set that value.
  • Lennie
    Lennie over 5 years ago in reply to steve
    Thanks Again. I was able to do that on some of the ARC's others I got errors trying to do that that forced me to move other segments to get it to make the ARC  a right angle. Unfortunately the  FLEX Zones you cannot use SHAPES to edit the arc which does allow you to slide ARC.s.
