  3. Converting Via into DXF marked circle
  • Replies 19
  • Views 21261
KARTHIK RANGARAJ
KARTHIK RANGARAJ over 5 years ago
I received DXF file from mechanical team. In DXF has some circle. I have to place via in that circle location.  Is there is any way to place via automatically  in the provided circle location.
  • masamasa
    masamasa over 5 years ago
    if u have a conversion tool, u can first change the lines to shapes and then change the shapes to padstacks.
    if u do not have the conversion tool, u can try this skill
    u can download the zip file.
    https://community.cadence.com/cadence_technology_forums/f/pcb-skill/7407/axlskill-function-to-convert-a-cline-to-a-shape
    for the shape to padstack conversion, u can type the following in the command line
    shape to padstack
  • KARTHIK RANGARAJ
    KARTHIK RANGARAJ over 5 years ago in reply to masamasa
    Thanks for your quick support  masa.  Regarding conversion tool. Is this cadence inbuilt or external one?
  • KARTHIK RANGARAJ
    Hi masa,
    i convert DXF circle into Shape in Allegro shape-->compose shape. I want to conver this shape  into pad stack or via
  • masamasa
    masamasa over 5 years ago in reply to KARTHIK RANGARAJ
    can type the following in the command line if u do not have the conversion tool?
    shape to padstack
  • KARTHIK RANGARAJ
    I tried but  i am getting error . please refer below error
    Shape command requires an argument
