  3. Get all .dra files in the library and extract footprint...
  • Views 16493
Get all .dra files in the library and extract footprint curve
Elias Ghossein
Elias Ghossein over 5 years ago
I need to loop over all component .dra file (or .psm) in the Allegro library and for each, extract the footprint curve. Can you provide a simple piece of code that:
1. Extract all .dra in the library
2. For each .dra file, access footprint curve data
I see that for (2),  we can use extracta.exe to extract/ convert .dra to ASCII. What should I put in the input file ?
extracta mysym.dra mycmd.txt out.txt
with mycmd.txt containing
FULL_GEOMETRY
CLASS="ETCH"
SUBCLASS="TOP"
OR
SUBCLASS="BOTTOM"
  PIN_NUMBER
  PAD_STACK_NAME
END
What should I put in mycmd.txt to extract the footprint curve location
The end goal is to create those curve in another CAD software.
Thank you in advance
