  3. Get info from all footprints in library
  • Replies 7
  • Views 22503
EvanShultz
EvanShultz over 5 years ago
I would like to write a report that gives 3D mapping info for all footprints in the library. I have written a report that works fine for all footprints on a board, so I should be able to simply swap out the list of footprints on the board with a list of footprints in the library. But I'm not sure how to do that.
getDirFiles(axlOSSlash(strcat(axlGetVariable("CDS_SITE") "//footprints"))) gives me a list of all footprints in the library, but I don't know how to access the footprint properties. The board report is as simple as symdef->prop->PKGDEF_STEP_FILE (and the other 3D model properties) for each footprint on the board, but that doesn't work with a pile of PSM files sitting out on a network folder.
Does anyone know how I can access the properties of a footprint on the network? I searched the forum and didn't find anything but I may have just not used the proper search terms. Thanks in advance for any help!
  • B Bruekers
    B Bruekers over 5 years ago in reply to EvanShultz
    Nice that you succeeded to parse the information.
    I assume you only need to run this once. If so then I suggest to copy all footprint files to a local drive. This will run much faster.
    1) you can set multiple items in the extracta option file. With axlExtractToFile() you can extract data from the current database to a ascii file. For example the ODB exporter is using this to generate several files for the actual ODB converter.
    2) I understand what the issue is, you want to sort the dra file list before you start extracta. If all of your DRA files are in 1 large directory then this is impossible without using extracta (and going through each file...) Maybe you can filter the footprints by the filename?
    The pp() is a pretty print and you can find it in the 'Cadence SKILL Development Reference'. (skdevref)
    push() is a default LISP macro. In SKILL it is actually a macro that calls cons().  So it basically does the same as a cons(), but it is shorter to write up:
    strings = cons("hello" strings)
    push("hello" strings)
    Skill > isMacro('push)  --> t
    Skill > expandMacro('push("a" x))   --> car(    (x = cons("a" x)))
    So the push uses cons() and returns the first element in the list (so the item that was added to the list)
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    regarding the documentation for ipcBeginProcess(), I just opened cdnshelp, searched for ipcBeginProcess which returned 7 results, the 1st was in 'Cadence Interprocess Communication SKILL Reference' which is in $CDSROOT/doc/skipcref
