  3. Get info from all footprints in library
  • Replies 7
  • Views 22501
EvanShultz
EvanShultz over 5 years ago
I would like to write a report that gives 3D mapping info for all footprints in the library. I have written a report that works fine for all footprints on a board, so I should be able to simply swap out the list of footprints on the board with a list of footprints in the library. But I'm not sure how to do that.
getDirFiles(axlOSSlash(strcat(axlGetVariable("CDS_SITE") "//footprints"))) gives me a list of all footprints in the library, but I don't know how to access the footprint properties. The board report is as simple as symdef->prop->PKGDEF_STEP_FILE (and the other 3D model properties) for each footprint on the board, but that doesn't work with a pile of PSM files sitting out on a network folder.
Does anyone know how I can access the properties of a footprint on the network? I searched the forum and didn't find anything but I may have just not used the proper search terms. Thanks in advance for any help!
  • B Bruekers
    B Bruekers over 5 years ago
    You need to do this with the extracta tool and run it on the DRA (not PSM) files.
    create a extracta command file, eg  c:\extracta.txt
    put these lines in this file:
    BOARD
    PKGDEF_STEP_FILE
    END
    Then start the extracta command line: (perhaps you need to run this from your <cds_root>\tools\bin  directory)
    extracta -q -s -k -r "footprint.dra" "c:\extracta.txt"
    This will return the PKGDEF_STEP_FILE information.
    From SKILL you can do this with a ipcBeginProcess() and read out the return with ipcReadProcess().
  • EvanShultz
    EvanShultz over 5 years ago in reply to B Bruekers
    Thanks!!
    I can get this info easily in the console, but I don't find documentation on ipc*Process() functions in COS or any of the SKILL function reference documents I usually look at. There are some examples of using these functions elsewhere on the forum but that doesn't necessarily tell me what I need to know to use there here. Do you know where I can find info on this series of functions?
  • EvanShultz
    Thanks again for the help.
    I decided to first try just getting a simple piece of data from the command window (I'm on Windows). So I placed the following into a procedure:
    axlMsgPut("%L" axlGetVariable("cwd"))
    o_ipcHandle = ipcBeginProcess("cmd.exe")
    axlMsgPut("%L" ipcWriteProcess(o_ipcHandle "date /t"))
    axlMsgPut("%L" ipcReadProcess(o_ipcHandle 3))
    axlMsgPut("%L" ipcKillProcess(o_ipcHandle))
    That returned the following in the Allegro console:
    ipc:1
    t
    "Microsoft Windows [Version 10.0.19042.685]\r\n(c) 2020 Microsoft Corporation. All rights reserved.\r\n\r\nC:\\Data\\DATA\\Projects\\Cadence\\test\\extracta>"
    t
    So I'm talking to the Windows Command Window and getting back the introductory message along with the prompt for the path of the board file. It seems promising, but it's not sending the command I wanted and getting back the expected date info.
    From the same path in a Command Window, typing "date /t" gives me: "Thu 01/21/2021".
    I tried replacing the second line of SKILL code above with the following, as seen at community.cadence.com/.../synchronous-input-output-interprocess-communication-example-does-not-work, but that didn't do anything different.
    o_ipcHandle = ipcBeginProcess("cmd.exe" ""  'myIpcDataHandler 'myIpcErrHandler 'myIpcFinishHandler "ipc.log")
    I then tried plowing ahead with the extracta command, using this:
    o_ipcHandle = ipcBeginProcess("extracta.exe")
    axlMsgPut("%L" ipcWriteProcess(o_ipcHandle "extracta -q -s -k -r 1DIP14.dra extracta.txt"))
    That returns the following:
    ipc:1
    t
    "ERROR(SPMHUT-39): Error retrieving the command line switches.\r\n"
    t
    So something is happening, but my simple test didn't quite work and neither did calling the extracta program. Any tips?
  • B Bruekers
    B Bruekers over 5 years ago in reply to EvanShultz
    Something like this should work:
    f_footprint = "c:/footprint.dra"
    f_extracta  = "c:/extracta.txt"
    cmd = lsprintf("extracta -q -s -k -r \\\"%s\\\" \\\"%s\\\" "  f_footprint f_extracta)
    timeout = 10
    cid = ipcBeginProcess(cmd)
    ipcWaitForProcess(cid timeout)
    result = nil
    while(str = ipcReadProcess(cid timeout), push(str result))
    result= reverse(remq(nil result))
    ipcKillProcess(cid)
    pp(result)
    Further the IPC api can be found in this help document: Cadence Interprocess Communication SKILL Reference
    Also take a look here for how to deal with special characters: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nZpCEAU&pageName=ArticleContent
  • EvanShultz
    Thanks! That does work and all the info links are very helpful as well.
    I removed the -s command switch for extracta since one of the 3D model properties has the elements delimited with a comma and the other with a comma and space. That almost seems like it would be a bug. Anyway, having the exclamation point delimiters is helpful and I can then parse down the long string of A, J, and S records as needed. Having the exclamation point delimiters on the S record also helps to know for sure if the primary model is offset and/or rotated and also the secondary model is mapped or not. Maybe there is a better way?
    While I need to finish things off, a small prototype of the code is working over a section of our library. It's going to be a lengthy process to do this for all footprints over a network, but that's fine and to be expected. So thanks again and hopefully I can take it from here.
    Two things I'm going to have to look into:
    1. I find in the extracta documentation for <outfile> that a maximum of 24 files is supported. I don't think this affects me since I'm running extracta on only one footprint at a time. But I haven't used extracta much so I could be missing something. We'll see.
    2. There's little point in running extracta on footprints that aren't package symbols in this case since I care about 3D mapping info. Flashes and shape-based footprints and other footprints which aren't of type PACKAGE or MECHANICAL won't have 3D info mapped (I haven't seen a need to map any, anyway) and I don't want them in the report. I can either find out how to extract that info from the footprint and filter the result from extracta or perhaps see if the DRA has a complementary file with an extension of PSM or BSM. I'll figure out one of those solutions, or need to do something else, as I finish the code.
    Ahh. I searched COS for "ipcBeginProcess()" and also "interproces communication" and neither turns up that document. One would think I would get a useful documents in the results for at least one of those terms...
    On a similar note, where can I find documentation for push() and pp()? They aren't in sklangref.pdf and COS also doesn't have any useful results I can find.
