  3. Merge Clines with same nets?
  • Views 14629
Gipper
Gipper over 5 years ago
I used "Place Replicate" to copy a large circuit in my project. Some of the Clines didn't line up correctly when applying the replication. Now, I'm finishing the Clines, and it is creating these "elbows" in the Clines that make the trace more difficult to work with. The elbows are shown in the attachment as a diamond shape.
Is there any way to merge the Clines to remove these areas?
Toolset is PCB Designer Professional 17.4-2019 S013.
  • Joewi
    Joewi over 5 years ago +1
    If don't plan on refreshing the replicated groups, you could disband the group. Or you can copy the clines from the group off the edge of the board, delete the clines from the group, then move the clines…
  • Joewi
    Joewi over 5 years ago in reply to Gipper +1
    In the find filter, select groups. Hover over the replicated group and right click. Now select disband group.
  • Joewi
    If don't plan on refreshing the replicated groups, you could disband the group.  Or you can copy the clines from the group off the edge of the board, delete the clines from the group, then move the clines you copied back.
  • Gipper
    Gipper over 5 years ago in reply to Joewi
    Joewi, this place replicate is a one-off so disbanding the group would be appropriate. I've searched around a little and have not found any options to disband. How would I go about doing that?
  • Joewi
  • Gipper
    Wonderful! Thank you.
