  3. Importing text logo in Cadence Allegro
  • Subscribers 166
  • Views 14705
lkrishna
lkrishna over 5 years ago
 Can anyone help me with importing of this logo ?
This logo has only text. I tried to import this logo which is in .bmp format in cadence allegro by using option - File/Import/Logo. It got imported but the letters did not look proper. I want the letters to look as it is in this image.
Image 2 is the result of importing.
Image 2----/resized-image/__size/320x240/__key/communityserver-discussions-components-files/28/1616.pastedimage1611752340540v2.png
  • steve
    steve over 5 years ago
    Look on the PCB skill forum for a skill file (an app) called Logomaker. This should do a better job of importing logos if the Cadence direct import is not giving you what you need,
  • CadAce2K
    CadAce2K over 5 years ago
    As Steve mentions, Logomaker is a good resource. Lately I've simply gone online and searched for converters to DXF. You can likely get a converter to take a picture image and convert it to DXF. When you import it might work, or not. Always worth a try. Pretty quick. I do recommend Logomaker though as a primary.
  • lkrishna
    lkrishna over 5 years ago in reply to CadAce2K
    Thank you for your reply... I tried DXF method too but the result didn't vary. The text was still not proper.
  • lkrishna
    lkrishna over 5 years ago in reply to steve
    Thank you for your reply... I will try this because this seems my only option.
