  3. PCB Editor: editing lines
  • Subscribers 166
  • Views 17842
eddoh
eddoh over 5 years ago
Hi
Is there a way to edit an existing line to extend-shrink it by moving its vertices?
Edit verticies does not seem to be the right command - so far I just understood how to trim and extend it, but a plain change ot the position of its vertices is still obscure to me.
Assuming it is possible...
Thanks!
  • excellon1
    excellon1 over 5 years ago +1
    The way to do this is using the "Vertex Tool" or you can use the keyboard command "Shift F9" When you hover your mouse over the end of a segment it will allow you to move the vertex around, extend…
  • eddoh
    eddoh over 5 years ago in reply to excellon1 +1
    oh thanks, I understood how to make it work. For newbies having the same issues - Line must be unselected first, then you activate edit vertex and then you click the vertex - the line should stick to…
  • masamasa
    masamasa over 5 years ago
    u can use the trim segments command.
    this works not on clines but only on lines.
  • excellon1
    When you hover your mouse over the end of a segment it will allow you to move the vertex around, extend, reduce etc
    All the best.
  • eddoh
    For newbies having the same issues - Line must be unselected first, then you activate edit vertex and then you click the vertex - the line should stick to the mouse pointer after that.
    If you start from a selected line, the command does not work and you just move the line around.
  • Hodgepodge
    Hodgepodge over 5 years ago in reply to eddoh
    Thanks, I'm embarrassed how long I searched for this solution until finding your recommendation. I'm using 174 and this worked, for some reason I can't shift F9, possibly due to working over a VPN from home to a work computer.
