  3. Can anyone tell me where I can find in a via dbid where...
  • Views 3542
Can anyone tell me where I can find in a via dbid where it stores the "Part of a via stack: 9 (TOP to BOTTOM)"
David M Gonzales
David M Gonzales over 5 years ago
LISTING: 1 element(s) < VIA > Zone name: ZONE_1B origin-xy: (1.3950 -15.3900) Part of net: GND Connected vias: 1 ( L9 ) Part of a via stack: 9 (TOP to BOTTOM) Padstack name: UM220V100L9L10 Usage: Bbvia CIRCLE_DRILL : 0.1000 Plated padstack defined from L9 to BOTTOM rotation: 0.000 degrees Via is not mirrored
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    I don't think that info is stored in the via
    try using axlDBGetConnect(via_dbid t)
  • David M Gonzales
    Hi David,  Thanks for the quick reply. I tried axlDBGetConnect(
    It seems whether I use axlDBGetConnect( or search in via_dbid->?
    it returns the same
    parentGroups symbolEtch branch pads definition
    isMirrored isThrough name objType parent
    net rotation mirrorType startEnd testPoint
    xy readOnly bBox prop fixedByTestPoint
    pluralVia relations
  • DavidJHutchins
    DavidJHutchins over 5 years ago in reply to David M Gonzales
    I did a 'show element' on a via that's part of a 'via stack', then issued a few skill commands, the journal file entries are shown below:
    \i (00:01:49) skill
    \i (00:02:50) skill 'via_dbid = car(axlGetSelSet())'
    (00:02:50) dbid:000000F7AEDE6278
    \i (00:03:05) skill via_dbid->??
    (00:03:05) (relations nil prop propList:000000F7B1873020 bBox
    (00:03:05) ((6287.51 1968.69)
    (00:03:05) (6303.51 1984.69)
    (00:03:05) ) readOnly t net dbid:000000F7AD776470
    (00:03:05) objType "via" pads
    (00:03:05) (pad:000000F7B0D6E778 pad:000000F7B0D6E750 pad:000000F7B0D6E728 pad:000000F7B0D6E700 pad:000000F7B0D6E6D8
    (00:03:05) pad:000000F7B0D6E6B0 pad:000000F7B0D6E688 pad:000000F7B0D6E660 pad:000000F7B0D6E638 pad:000000F7B0D6E610
    (00:03:05) pad:000000F7B0D6E5E8 pad:000000F7B0D6E5C0 pad:000000F7B0D6E598 pad:000000F7B0D6E570 pad:000000F7B0D6E548
    (00:03:05) pad:000000F7B0D6E520 pad:000000F7B0D6E4F8 pad:000000F7B0D6E4D0 pad:000000F7B0D6E4A8 pad:000000F7B0D6E480
    (00:03:05) pad:000000F7B0D6E458 pad:000000F7B0D6E430 pad:000000F7B0D6E408 pad:000000F7B0D6E3E0 pad:000000F7B0D6E3B8
    (00:03:05) pad:000000F7B0D6E390 pad:000000F7B0D6E368 pad:000000F7B0D6E340 pad:000000F7B0D6E318 pad:000000F7B0D6E2F0
    (00:03:05) pad:000000F7B0D6E2C8 pad:000000F7B0D6E2A0 pad:000000F7B0D6E278 pad:000000F7B0D6E250 pad:000000F7B0D6E228
    (00:03:05) pad:000000F7B0D6E200 pad:000000F7B0D6E1D8 pad:000000F7B0D6E1B0 pad:000000F7B0D6E188 pad:000000F7B0D6E160
    (00:03:05) pad:000000F7B0D6E138 pad:000000F7B0D6E110 pad:000000F7B0D6E0E8 pad:000000F7B0D6E0C0 pad:000000F7B0D6E098
    (00:03:05) pad:000000F7B0D6E070 pad:000000F7B0D6E048 pad:000000F7B0D6E020
    (00:03:05) ) branch
    (00:03:05) dbid:000000F7ADEABF70 pluralViaConnect nil pluralVia nil
    (00:03:05) fixedByTestPoint nil isThrough nil xy
    (00:03:05) (6295.51 1976.69) testPoint nil name "VIA10P4_L1_L2"
    (00:03:05) startEnd
    (00:03:05) ("ETCH/TOP" "ETCH/L2-GND") rotation 0.0 symbolEtch
    (00:03:05) nil parent dbid:000000F7ADEABF70 mirrorType "NO"
    (00:03:05) isMirrored nil definition dbid:000000F7AD7A27D8 parentGroups
    (00:03:05) nil
    (00:03:05) )
    \i (00:04:14) skill 'data=axlDBGetConnect( via_dbid t)'
    (00:04:15) (dbid:000000F7AEDB51D0 dbid:000000F7AEDE3010)
    \i (00:04:38) skill d1=car(data)
    (00:04:38) dbid:000000F7AEDB51D0
    \i (00:04:57) skill d2=cadr(data)
    (00:04:57) dbid:000000F7AEDE3010
    \i (00:05:00) skill d1->??
    (00:05:00) (relations nil prop propList:000000F7B1873038 bBox
    (00:05:00) ((6287.51 1968.69)
    (00:05:00) (6303.51 1984.69)
    (00:05:00) ) readOnly t net dbid:000000F7AD776470
    (00:05:00) objType "via" pads
    (00:05:00) (pad:000000F7B0D6EEF8 pad:000000F7B0D6EED0 pad:000000F7B0D6EEA8 pad:000000F7B0D6EE80 pad:000000F7B0D6EE58
    (00:05:00) pad:000000F7B0D6EE30 pad:000000F7B0D6EE08 pad:000000F7B0D6EDE0 pad:000000F7B0D6EDB8 pad:000000F7B0D6ED90
    (00:05:00) pad:000000F7B0D6ED68 pad:000000F7B0D6ED40 pad:000000F7B0D6ED18 pad:000000F7B0D6ECF0 pad:000000F7B0D6ECC8
    (00:05:00) pad:000000F7B0D6ECA0 pad:000000F7B0D6EC78 pad:000000F7B0D6EC50 pad:000000F7B0D6EC28 pad:000000F7B0D6EC00
    (00:05:00) pad:000000F7B0D6EBD8 pad:000000F7B0D6EBB0 pad:000000F7B0D6EB88 pad:000000F7B0D6EB60 pad:000000F7B0D6EB38
    (00:05:00) pad:000000F7B0D6EB10 pad:000000F7B0D6EAE8 pad:000000F7B0D6EAC0 pad:000000F7B0D6EA98 pad:000000F7B0D6EA70
    (00:05:00) pad:000000F7B0D6EA48 pad:000000F7B0D6EA20 pad:000000F7B0D6E9F8 pad:000000F7B0D6E9D0 pad:000000F7B0D6E9A8
    (00:05:00) pad:000000F7B0D6E980 pad:000000F7B0D6E958 pad:000000F7B0D6E930 pad:000000F7B0D6E908 pad:000000F7B0D6E8E0
    (00:05:00) pad:000000F7B0D6E8B8 pad:000000F7B0D6E890 pad:000000F7B0D6E868 pad:000000F7B0D6E840 pad:000000F7B0D6E818
    (00:05:00) pad:000000F7B0D6E7F0 pad:000000F7B0D6E7C8 pad:000000F7B0D6E7A0
    (00:05:00) ) branch
    (00:05:00) dbid:000000F7ADEABF70 pluralViaConnect nil pluralVia nil
    (00:05:00) fixedByTestPoint nil isThrough nil xy
    (00:05:00) (6295.51 1976.69) testPoint nil name "VIA10P4_L2_L3"
    (00:05:00) startEnd
    (00:05:00) ("ETCH/L2-GND" "ETCH/L3-SIGNAL") rotation 0.0 symbolEtch
    (00:05:00) nil parent dbid:000000F7ADEABF70 mirrorType "NO"
    (00:05:00) isMirrored nil definition dbid:000000F7AD7A1E58 parentGroups
    (00:05:00) nil
    (00:05:00) )
    \i (00:05:10) skill d2->??
    (00:05:10) (prop nil bBox
    (00:05:10) ((6289.4 1974.24)
    (00:05:10) (6304.04 2085.8)
    (00:05:10) ) readOnly
    (00:05:10) t net dbid:000000F7AD776470 objType "path"
    (00:05:10) thermal nil segments
    (00:05:10) (dbid:000000F7AEDE2D70 dbid:000000F7AEDE2F28 dbid:000000F7AEDE4F78 dbid:000000F7AEDE2DD8 dbid:000000F7AEDE36C0
    (00:05:10) dbid:000000F7AEDE2CF0 dbid:000000F7AEDE3848
    (00:05:10) ) isEtch
    (00:05:10) t nSegs 7 hasArcs t
    (00:05:10) isSameWidth t branch dbid:000000F7ADEABF70 layer
    (00:05:10) "ETCH/TOP" symbolEtch nil parent dbid:000000F7ADEABF70
    (00:05:10) parentGroups nil
    (00:05:10) )
  • David M Gonzales
    David M Gonzales over 5 years ago in reply to DavidJHutchins
    Yes, now I see it. axlDBGetConnect( branch/startEnd will get the next via(s) in the stack. Run the same on that via, on so on. Eventually you will get the range of the entire stack.
    Thanks a lot!
